please send me link for new firmware for HCL :)
i want to upload it to my HCL manual :)
  • 1 month later...
I'm also in search for the latest firmware file for HC Lite, did you ever get the link for download?
please contact with support. I think they don't have time to read forum.
You're right, I contacted support and sent me a link.
I find it odd that support don't just have all the firmware available for download here on this forum. That would have saved them a lot of time helping people with trivial requests :-)
  • 3 weeks later...
Did you find the update?
could you give me that link?
  • 8 months later...
Did you fond it? Please send to me.
Can you give to me update download link?
@KhishigbayarHello and welcome to the community.
About your request for a Firmware download link. That's not how it works, there's no download link.
If you have Fibaro homecenter Lite: Connect it to the internet > wait a few minutes > login to the homecenter with a browser > go to configuration > check which firmware you have now > if there is an update > a button will come up and ask you to update to the latest firmware release > procede and update the homecenter.
The latest Firmware for Homecenter Lite is 4.630.
If you don't know which IP adress the homecenter has got, the fibaro finder is
 (scroll down)
Edited by Fabir
  • 1 month later...
Well, I'm on version 4.540 and trying to get the latest update when requested. This message comes up. I'm new to the FIBARO ecosystem and not really impressed so far.
  • 1 month later...
 (scroll down)
Hi!
(First post...)
Just got myself an HCL, and it has sw version 4.150 out of the box.
From what I understand, there should be at least a version 4.5+ available.
However, in my Home Center (via local access) there are no updates 'offered'.
System's been up a good 30+ hours, and I can log on from remote access..
What do I need to do in order for it to be upgraded to latest version?
@Markus Forsberg Hello and welcome to the community.
First you need to setup a Fibaro ID. How to do that, is
. The latest firmware for fibaro homecenter light is 4.630.
You worte:
Hi!
(First post...)
Fibaro homecenter Light HCL and HC2 are EOL, End of Live. Meaning no more updates from fibaro. If you've god your hcl free, for testing and learning, why not OK.
If you have bought the homecenter light, consider to give it back. The newer homecenters:
Homecenter3,
Homecenter 3 Light
Yubii home
are more versitale and easier to use. Checkout the comparsion sheet from fibaro
HC3 is quite expensive. If your use case doesen't exeed the limits, I reccommend to start with a Yubii home, which is not expensive.
You worte:
Hi!
(First post...)
Homecenter3,
Homecenter 3 Light
Yubii home
Thanks!
For whatever reason, without doing anything, the update became available just within an hour of me posting this..
So now it's up to date...
Got it cheap, so no worries about EOL 😃
I'll play around with this, might consider an upgrade down the road..
Cheers!
  • 1 year later...
Hello
Please send me the firmware for Home Center Lite
Thank you
The device is in this state.
  • 6 months later...
My device is stuck in “ starting service”. Tried reboot, repair but nothing seems to work. Any advice
