Joaquibaro 0
Hello there!
I saw on Amazon US a question from a user, asking between the voltages supported for the Dimmer 2 (FGD-212) and there is a Fibaro official reply saying 120-220VDC (attached).
After reading all the supporting documents available at
I understood there are different versions of them, mostly because of the frequencies supported for the Z-Wave network. Even though that is true, manuals state that the module supports 100-240 V~ 50/60 Hz (attached), as if there is only one version of power support.Unluckily if you go into the short manuals for US and European, you will find that they state "FGD-212 - 120VAC" and "FGD-212 - 220-240 V~" respectively but never mention a difference on the version of the module. What is even more confusing is that the short manual for US comes with an extra block of information in Chinese (ZH) that says "FGD-212 - 220-240 V~", in the same paper (checked with a friend in USA).
Could it be that the module supports 120-240 always as stated on Fibaro's answer from Amazon and we are just seeing a relabeling? Then the version is just for the different frequencies for the Z-Wave network... Anyways, does anybody know more about this? Or maybe even tried that?
Is there any way to check this by opening the module?
Thank you in advance, have a nice one!
