Matthew Davies 0
I have a staircase lighting system where 2 x 3-way (SPDT) wall switches can operate the lights, and I'd like to automate the lights, to turn them off if accidentally left on, etc etc.
I searched in the forums and found the diagram below. The problem I have is the load wire (the red wire going from L on the right hand side switch to S1, plus the grey wire) is not available in the box where I would need to install the Switch, and running that cable would be a major hassle in my house.
Is there a way to use a Fibaro Single Switch 2 (or other Fibaro device) to automate without having that wire available? For example, is there a device which would work on the 2 outputs of the first wall switch (the 2 red lines going from left to right) to automate the lights?
Thanks!!
/monthly_2021_11/FGS212-Trappkoppling-switch.png.e8e9d118167a6054ecf13d500783d4a0.png" />Link to comment
6 answers to this question
