Bechor 0
Hi ..
It is possible to connect a magnet sensor to an entrance gate, which will be connected directly to the switch (Double Switch 2, 2x1,5kw, FGS-223) instead of the ignition button, then when the gate opens the light will turn on for a minute ?
problem
1. When the gate is closed within the time frame of the minute, the light will not turn off.
2. That the scene should only run after sunset.
3. During the day when there is sunlight, the lighting will not turn on / or turn on for only seconds and trun off if it inpossible.
I have been trying for days without success, I would appreciate any help, thank you very much!!
