Set Local Protection LUA
Hello All,
How can I set Local Protection from LUA? (On Fibaro The Heat Controller)
I see that there is a properties.localProtectionState what is 0 if turned off and 2 if I turn on the local protection.
But if I turn off with the slider in device settings advance tab and set the property to 2 nothing happens.
Is there any other property what I did not find in swagger?
Do anyone has a useful idea, how can I step forward?
Thx
Milan
4 answers to this question
    OK. Got it.
    It is a simple hub.call
    just have to know the correct device ID. This can be a surprise. In some cases the remot, or one of the hiddens, or something…
    to turn on local protection:
    For Danfoss thermostatic heads it is identical ?
    12 minutes ago, SvenG. said:
    Thanks, but it will not help.
    I have to write a scene, because I have 135 devices where I need to activate the local protection.
