Force motion sensor to safe mode
Mauric
Hello there,
I have a scene that turns on the lights in the kitchen when one of two sensors are breached. Then to keep the lights on I set parameter 6 to 4 minutes before going back to safe after the breach.
But when I leave the house via the kitchen the lights turn of and stay's on for 4 minutes after I'm gone.
I got The Button near my door and want to force the lights out when I leave, but because the breached mode is still on the lights turn back on.
I's there a way to force the motion sensors back into safe and turn of the lights using the button?
I'm using the HC2 as controller.
Thanks in advance
12 hours ago, Mauric said:
Hello there,
Thanks in advance
After switching the light to OFF by "The Button" it should stay OFF even the sensors are still breached. Your scene triggered when the sensors breached only and no triggers during 4-6 minutes per your setup
Two questions
1. What do you mean by "The button"? Is it Zwave switch?
2. Could be that when after switching "The button" on your way out you breach the second sensor?
Edited by cag014
  • I use the fibrao button
    And no I can't trigger the second sensor because the button is in a different room.
    So therefore I believe it has something to do with the fact that I set parameter 6 to 4 minutes, but if I reset this parameter then the lights turn off during dinner.
