Prokopis Bor 7
Hello! I have been facing the following problem for a long time. I have some smart Implant modules that I have set their inputs to NO. If for some reason their power supply is cut off and restored, and during this time any input happens to change state, then the Fibaro Gateway (I'm using HC# and HC3L) does not realize this change and therefore keeps the old input state. For example I have an "OFF" state, the module power supply is cut, the sensor state connected on smart implant input change to "ON" and when the power supply is restored, Fibaro Gateway doesn't realize the state change to "ON" and still shows "OFF". In other words, the input should be turned "OFF" and "ON" again, for Fibaro Gateway to understand the change. The same happens, even if the Gatewaty is rebooted. Has anyone found a solution to this problem?
Edited by Prokopis Bortypo
