Temperature scene
Need help setting up a block scene for HC3 based on outside temperature.
When the temperature drops below -5 degrees and colder, a heating coil connected to the wall plug turn on and when the temperature rises above 0 degrees, it switches off.
5 answers to this question
Sounds like you need to have two blockscenes, for turning on and for turning off.
What do you have up til now?
    I have done this two different scenes, but not sure if they should be >= or == or > in symbols
    Looks ok. Maybe you should also add a notification, next to turning on or off the heating coil. So you get some insight.
    ok!
    thanks for the support.
    but have I understood it correctly that >=0 means that when the temperature is = 0 or above 0 it turns off the system and <= -5 means that when the temperature is -5 or lower like -10 it turns the system on?
    Indeed, in text:
    temperature greater than or equal to zero
    temperature smaller than or equal to minus five
    ofcourse you could experiment a bit with the blockscenes. Just use only a notification or a light. I don’t know if it is already that cold in Sweden, but you could use the temperature range of, for example, -1 to +3 if that temperature is around the current temperature in Sweden.
