Can´t add device etc.
Trying to setup my Home Lite. Can´t add device. My user interface does not look as I would expect it to be.
Any advice would be greatly appriciated!
4 answers to this question
Välkommen!
Could you maybe add a screenshot of the interface, maybe then we can see what might be wrong.
Also, what kind off device are you adding. Just some more info might be usefull.
    1 hour ago, ppeterr said:
    Välkommen!
    Hej - och tack :-)
    Its just empty for some reason. I had it upp and running but for mysterius reasons nothing worked any longer and I had to reset the Home Lite. Trying to add a Flood Sensor.
    5 minutes ago, pkaufmann68 said:
    Hej - och tack :-)
    Strange that I cant run this secure, even though it is on "my side".
