MCO thermostat mh7wh changeing temperature
Gabor1
Hello All!
I have a problem. MCO mh7wh thermostat changeing temperature itself. The thermostats are in manual mode, on the app says heating. I wrote a script, if the thermostat changeing mode, change it back to heat. Still it is changeing.
I have this problem both HC3, HC2.
On HC2 after the latest update, after soft reconfigure the thermostats it seems ok.
I never had this problem with HC3, until recently it is started. ANyone faced with the same issue, and come up with a reliable solution?
Thank you in advance.
Gabor
I've currently had a simliar issue with HC2 and the Horstmann stat, operating the boiler controls whilst the schedule was dictating no heat the stat decides to turn on the boiler. Have tried putting schedule into Manual, but it is still over riding and controlling the boiler.
