Bathroom fan "Helios ELS-V 60/35" control
Dear,
I would like to control bathroom fan "Helios ELS-V 60/35". Currently the fan is connected to the double wall switch, it allows to control two speeds of the fan.
Could you please advise if to control such equipment a double switch or double smart module should be used? Attached I am sending the electrical diagram for fan connection.
Thanks in advance for all replays.
Kind Regards,
Michal
@inspirit
Yes, you can connect the fan via FGS-223.
Attention, if you switch the lighting at the same time, you need a separate switch (contact), see diagram.
@inspiritHi, quite often, there isn't enough space to hide a Fibaro module behind an existing switch.
Therefore, if you like the design, I suggest you to use a
to do this job.
    On 11/19/2022 at 9:42 AM, Martin_N said:
    @inspirit
    Thanks for a replay, could you please advise how to connect such fun to the Fibaro Double Switch?
    @Martin_N
    Could you advise how to perform the connection?
    My problem is that I have currently 3 wires in the existing wall switch.
    1x L wire
    1x wire to operate speed 1
    1x wire to operate speed 2
    Probably the N wire is on the fan. In this case the FGS223 should be located on the fan side to have the N wire connected?
    Thanks in advance.
