Problems with manually changed temperatures in climate zones
Hi, I think that there is a GENERAL problem with MANUALLY changed climate panel values: when you set for a climate zone a new temporary/manual value of f.i. 24°C for the next 24 hours, this setting is not transmitted to the HVAC systems.
Anyone already noticed this behavior ?
We are on it.
I will keep you posted.
    On 11/21/2022 at 3:42 PM, m.roszak said:
    We are on it.
    Thanks for the effort made. It's really necessary to look into the problem.
    We have even heaters that start to heat even when no commands are sent to the FGT-001.
    Very strange behavior indeed.
