I am using FGDW as temp sensors in the rooms. It's not changing the temp indication to often. I change parameter 50, 51 and 52, but it didn't help. The last one I think might create an issue is WAKE UP interval. It is set to 21600s and I cannot adjust it. Can someone help me with it please.
Wake up interval does not have any impact on reporting frequency. It just wakes up the device and apply the changed prameters. When you use a battery powered sensor and you change some paramater, you can easily manualy wake it up to get the data updated. Usualy the manual wake up is just a button press on the sensor. On the other hand. I dont know the 50,51,52 parameters definition as i am not using that sensor, but i am pretty sure, there are settings like "Minimum temperature change" or "Periodical reporting" that are affecting this behaviour. These two are mainly responsible for reporting frequency. I had some similar sensor in the past, and I used the "Minimum temperature change" for reporting, and I adjusted it to 0.1 °C, and it worked for me.
    @Neo Andersson thank you for reply
    This is an issue. Parameters 50, 51, 52 are related to reporting temp change, but they do not performed as should. Few days ago I check it manualy by removing the battery from the sensor and temp change for more than 2 degC!!! Settings are to report temp every 15 min and when change for more than 0.2 degC. This is not one sensor only. All of them are perform exactly the same.
    • 6 months later...
    I think wake up interval will not solve the issue. It has no impact on reporting frequency.
    • 4 months later...
    Are we talking about inbuilt temparture sensor of Fibaro FGDW's door/window sensor??
    Wake up interval will not have impact on value reporting frequency.
    Parameters 50,51 ad 52 are responsinle for temperature reporting.
    If you enable 52 and set some time, it means, that measured values will be sent always in given time period regardless of the settings in 50,51 which are responsible for treshold check and report.
    If your settings are correct, and you still not getting rerports, i am suspecting that it must be a range issue or faulty device.
    Beeing you i would try a soft reconfiguration or a complet re-inclusion. If it doesn't help, you might need to reach out for Fibaro official support.
