Milos5888 0
Hello
I have question, in My new flat Idecided to change the current system for controlling the roller shutters to Fibaro rs3. They had same modules as Fibaro put behind the Switch so i ve just exchanged them for Fibaro modules All work fine locally. However there is still central Switch by the door to control the shutters so there are additional wires in every local mounting hole coming from the central switch I installed there Walli roller shutter and locally installed the wires to s1s2 parallel to local switches and its not working well some shutter go up some just go down etc not sure what’s wrong
Edited by Milos5888Granmar
