raoul170 0
Hi
I am trying to get a doorsensor to do the following:
switch light A on for 30 minutes, it does not matter if the door closes or is opend a triggerd switch means 30 minutes ON, or incase the ligth was already on it stays ON (preferably starting the 30 minutes sequense oveR)
The switch that drives light A is a FGS-223, (double switch 2) wich is also connected to light B, and switch B, adittionaly I would like to have a scene where switch A turns on Light B for 30 minutes when it is pressed 2x for example.
can anybody shed some light on the needed settings.
Raoul
