fibaro.getGlobalVariable(cS) Why?
a="test"
b=tonumber(fibaro.getGlobalVariable(a))
Dit does not work
But
a="test"
b=fibaro.getGlobalVariable(a)
c=tonumber(b)
Why in QA not working the first one???
fibaro.getGlobalVariable returns 2 values. String value of variable and time it was last changed.
Modified is the timestamp in epoch, seconds since 1970 - usually some really large number.
Both these values in your example are then passed to tonumber as arguments
The problem is that tonumber can take an optional second argument, the base for the string->number conversion.
In this case it will interpret the modified time as the base which is of course out of range.
It will give an error message that is of type "base out of range"
You can throw away all but the first returned value from a function returning multiple values by putting the expression within parentheses.
This will work...
A similar problem is json.decode that in QAs can take a second argument that is expected to be a table with decoding options.
Will fail...
Will work...
    thanks for the explanation.
    the problem with json i got that to :)
    but this was not a problem in HC2 or........was it!
    (()) is much nicer thx
