Yubii heating panel Zone names ?
I am using version Yubii 1.17.0 on my iPhone 12 mini.
When I open the heating panel it gives me a list of all my heating zones. The problem is that the field available for each zones name is only 15 characters long.  Fibaro put the phrase "Temperature in" before each Zones name.
This means that every zone just shows up as "Temperature in..." so you cannot tell which zone is which.
Furthermore if you then select a zone the name at the top of the screen  only has another 4 characters available so even then you can't see the full name.  For example I have two zones Main Bedroom and Main Bathroom.  If I select a heating zone it shows the names of the zone as "Tempature in Main...".  So I still cannot tell which zone I am looking at.
We already know we are looking at the heating panel so the use of the words "Temperature in..." is unnecessary.
Is there a way to change this?
    Post submission I found the solution.  The Home Centre 2 gives a default name such as "Temperature in Main Bedroom".  This can be changed in Home Centre 2 to something like "Main Bedroom".
    Problem Solved.
