Measure Power Generation from solar module?
Hi All,
is there a Fibaro module that is able to measure power generation coming from a solar module (600w max)? I tested it with single switch and wall plug without any luck. Please, let me know measure the generation is possible with any device.
Oliver
For energy reading you can use products like the
And
These are compatible with the HC3.
Please tell us the device vendor/type to help you better.
    Thanks for your answer. I am using it on a mini-pv that is plugged into a regular power plug (Schuko). Therefore I would like to use either a Power Plug or a device like the Fibaro single/double switches to read that. I do not have it wired up into the fuse box to use the smart-meter devices. Do you know if the Qubino Smart Plug 16A is able to do that?
    Oliver
