Dear community,
I have recenty bought a Yubii Home box in order to control some zwave sensor and I can't find the way to link this box to my Home Assitant portal.
Anyone can support on that?
Thanks in advance.
Pierre
Why not use a much cheaper z-wave stick from aeotec and zwave-js or other addon for homeassistant?
Try
    Thanks for your reply!
    I am really new on the topic so not sure how to proceed exactly... I have followed the topic you shared @danidani and installed the QuickApp on my Yubii box and configured the MQTT client.
    Not sure from then what to do in Home Assistant... I have added the Fibaro integrator (
    ) and here is below the information that are required... impossible to figure out what URL I should enter or if it is the right way to do.
    /monthly_2022_12/image.png.e69b1c5f544a1f8be0e609e8b5203986.png" />
    thanks again for your support!!!
    I don't think Fibaro integration uses MQTT.
    MQTT can also work but then you have to install the Mosquitto Broker extension and the Mosquitto Broker MQTT integration.
    Then you can communicate with your QuickApp.
    If you choose to use the Fibaro integration, replace "HOST" with your Yubii IP address.
    Yes, I have installed an official Home Assistant Add-on: Mosquitto broker in and
    integration in my HA system.
    Then the configuration in HC3 is:
    /monthly_2022_12/image.png.7e5a0385008f6b8386e01e9f361dcbc2.png" />
    Edited by danidani
