No scenes in Alexa after HC2 hw swap
RiccardoCanetta
Hi all,
I had to replace my working HC2 due to hw issues. After restoring backup I went to Fibaro RemoteAccess and selected the new HC2 for the active Integration. After this, everything was working from Alexa but not the scenes (that were working before). So I tried everything: I deleted all items, re-created link between Alexa and Fibaro, I also tried the Yubii skill but the result is always the same: all devices are there but not the scenes, not even a super simple Block scene I just created that only turns on a light.
Any hint on what else can I try?
Thanks!
R
  • Solved - the supersimple scene that I thought I had created correctly, in fact, was incomplete and for this reason it was not showing up. As for the others, I had to recreate the LUA ones and edit the non-LUA ones so that they didn't violate any rule and then I could finally seee them in Alexa!
