Learning mode error. Try again. while adding Walli Dimmer FGWDEU-111
I'm trying to add Walli Dimmer FGWDEU-111 to HC Lite V4.630 and no success so far. No other controllers in my network. HC as well as Walli Dimmer where reset few times - same result:
[20:02:22] Home Center in learning mode
[20:02:26] Device added
[20:02:26] Requesting neighbours, please wait...
[20:02:29] Learning mode error. Try again.
[20:02:29] Adding devices complete
After this operation - device is not visible in HC.
Please help as I got lost with ideas..
  • 1 year later...
I have a similar problem, I can't remove or add any switch module. Someone with any solution?
@WalterWaB Hello and welcome to the community.
First check if your hcl and the switch modules you want to include, have the same zwave frequency.
The list for the zwave regions is
Than please give Infos about your hcl firmware relaese and the modul you want to include?
