Automatic heat control of panel oven using Eventrunner on HC3
Hi.
First, to my surprise I haven’t been able to find anything on this subject which I thought would be very common. Especially these days since the electricity bills are going through the roof.
Case
What I would like to do is to control the heat from my panel oven in my house using ER4/HC3. The panel- or convector oven will be connected to a Fibaro wall plug. A Fibaro motion sensor in the room should be used to detect presence and temperature. The solution should be able to lower the temperature on daytime to X degrees and bring the temperature up in the afternoon when presence is detected.
This can probably be solved extremely elegant using Eventrunner. If you do know about a similar case or have a suggestion on a smart ruleset it would be very appreciated if you could share it. Thank you 😊!
