Still a problem: Thermostats do not always respond to manual setting from the climate panel.
In the release notes of the .64 it is said that the bug "Thermostats do not always respond to manual setting from the climate panel. " was fixed.
We installed the .64 and still have the same problem.
Also, when a particular heater is set for a certain temperature for let's say 45 minutes, only the 45 minutes is sent to the heater, not the new set temperature.
Who else encounters these problems?
The .64 version has a lot of problems with thermostats & climate zones.
If this continues like that we will have to roll back to a previous version...
A new hotfix is urgently needed. We loose too much time investigating, debugging and dealing with the situation.
Edited by philv
was noty complete yet
