Greetings,
I would like to ask for a help with lua code.
Currently I'm running HC3L and it's exclusively used for house heating control (code below).
The scene checks the temps every 60s and turns on the boiler (and pump) if difference between required and real temperature is more than 0.5°C. I would like to keep the pump running for 15 minutes more after turning the boiler off.
Many thanks for any hints or help
m.
declarations
actions
Edited by Matej_svk
code inserted properly
(If you use the <> in the edit menu to show the code, everone can read your code a lot better)
Edited by SmartHomeEddy
