JoshGreenUK 0
I have some Fibaro 2 Dimmers, I am greatly concerned about them burning and catching on fire, I see there are some reports on the forums of this mainly from Dimmer 1 but also a couple on Dimmer 2. Not really sure what I am asking but because of the reports its enough to make me reconsider Fibaro equiptment as it will be nested in timber walls and timber floors.
EDIT: In the Dimmer 2 burning posts, there are next to no replies which also doesn't fill me with confidence of Fibaro's response. My main concern is why the over temp sensor didnt kill power before it was melted.
Additionally, I have Load error on 2 of the 3 dimmers I have setup, all are the same lights but the 2 with load error have 12 and 10 spotlights (Philips 6.3W Master Dimmable) each. Cannot work out what the problem is here and coupled with the above, greatly concerning. The lights seem to independently switch between dim levels at low dim, this is also really frustrating and didn't happen with Varilight V-Pro dimmer, so wondering what could be causing this?
Edited by JoshGreenUK5 answers to this question
