jeno 0
I am using Fibaro HC3 and e.g. Fibaro Dimmer 2 are installed in most of my Euro wall boxes. Considering to install 6 x LED panels in ceilings in my garage. Initially I was considering 4000K LED panels and using a Qubino Flush Dimmer 0-10V behind switch on wall in order to be able to dim them. However, now I have an idea that I want LED panels which are dimmable + possibility to change temperature (kelvin) on them.
I found these LED panels from SG:
SG have also introduced switches such as
where it is possible to dim and change temperature.Furthermore they have introduced a smart gateway for their light and switches:
My questions:
1) Anybody know of a solution making it possible to both dim and change temperature on a given LED panel (not only panels from SG)?
2) Anybody familar with integration of SG (with or without SG gateway) in HC3?
Appreciate all inputs. Thank you in advance.
Br. Jesper, Denmark
