I’m struggling with the syntax for “table.insert” on nested tables and can’t find the answer on tutorials I've read. Any help much appreciated.
This is the table format I’m using
bright = {
rgbw_1 = {r=38, g=13, b=1, w= 1},
rgbw_2 = {r=43, g=23, b=88, w= 20},
I can call a value without a problem using…
r=bright.rgbw_1.g
I can update a value without a problem using…
bright.rgbw_2.r=60
What I cannot figure out the syntax for is inserting a new line into the table. I’ve tried every combination I can think of
table.insert(bright,{rgbw_3={ r = '*1', g = "*2", b = '*3', w = '*4'}}) - no line error but pairs throws error "bad argument #1 to 'for iterator' (table expected, got nil)""
table.insert(bright{rgbw_3,{ r = '*1', g = "*2", b = '*3', w = '*4'}}) – error “attempt to call a table value (global 'bright')”
table.insert(bright,{rgbw_3{ r = '*1', g = "*2", b = '*3', w = '*4'}}) – error” attempt to call a nil value (global 'rgbw_2')”
table.insert(bright,[rgbw_2,]{r = '*1', g = "*2", b = '*3', w = '*4'})- error “unexpected symbol near '['”
table.insert(bright,[rgbw_2]={r = '*1', g = "*2", b = '*3', w = '*4'})- error “unexpected symbol near '['”
table.insert(bright,[rgbw_2,]={r = '*1', g = "*2", b = '*3', w = '*4'})- error “unexpected symbol near '['”
table.insert(bright,{"rgbw_3"={ r = '*1', g = "*2", b = '*3', w = '*4'}})– error” '}' expected near '='”
table.insert(bright{"rgbw_3",{ r = '*1', g = "*2", b = '*3', w = '*4'}})– error “attempt to call a table value (global 'bright')”
-table.insert(bright,{"rgbw_3"{ r = '*1', g = "*2", b = '*3', w = '*4'}})– error “--'}' expected near '{'”
As usual probably something super simple. Thanks for helping.
You're trying to append an object to a dictionary.
You should use association like
To make it happen your dictionary should become an array (there should be no keys). Something like this:
Rest of your examples are not a valid LUA syntax.
Same issue when you iterate over array and dictionary:
VS
When you access dictionary you use keys, like this:
But when you access array you need to go like this:
Edited by irekk
    Hi there @irekkThanks for your help, I really appreciate it.
    To use the array as you describe I will need to change how I use the data from tables, but I think its possible. In the mean time I made some new learning today which are confusing me……
    Part 1 – from yesterday
    As mentioned yesterday, I can create a file in the format I like to use and save as global variable. I can access the dictionary and update it, but for the reasons you described, I am not able to insert new lines.
    bright = {
    Appears like this as a global variable
    {"rgbw_2":{"w":20,"g":23,"r":43,"b":88},"rgbw_1":{"w":1,"g":13,"r":38,"b":1}}
    I can access it like this
    bright=json.decode(fibaro.getGlobalVariable("gTestBright2"))
    local r
    r=bright.rgbw_1.g
    print(r)
    returns 13
    But as you explained I can’t add new lines using table.insert
    Part 2 – from today
    I started with an empty array {}, saved as a global variable. Then I was able to use table.insert to insert data in the format I prefer. See example below.
    I created an empty {} and saved as a global variable
    bright = {}
    jt=json.encode(bright)
    fibaro.setGlobalVariable("gTestBright2",jt)
    When I look at the variable it is stored as
    Next I can insert data in the format I want to use
    [{"rgbw_3":{"w":"*4","b":"*3","g":"*2","r":"*1"}}]
    Interesting, it’s the same as Part1 but with [   ] at the ends
    I can add insert another line in the format I prefer
     table.insert(bright,{rgbw_4={ r = '*10', g = "*20", b = '*30', w = '*40'}})
    [{"rgbw_3":{"w":"*4","r":"*1","g":"*2","b":"*3"}},{"rgbw_4":{"g":"*20","w":"*40","b":"*30","r":"*10"}}]
    But I can’t access the file
    local r
    r=bright.rgbw_1.g
    print(r)
    error “attempt to index a nil value (field 'rgbw_1')”
    r=bright[rgbw_1][g]
    error – “attempt to index a nil value (field '?')”
    Summary
    The first approach I can make a dictionary, I can save as a global variable, I can access & update data but I can’t insert new data rows
    The second approach I can make a dictionary, I can save as a global variable, I can insert new lines in the format I prefer but I can’t figure out how to access the data !!
    If I can work out how to access the data in the second approach, then bingo !! Otherwise I will reconfigure the way I work with data files into simple arrays.  Any thoughts on this? Thanks in advance
    • 1 month later...
    I wrote the above to see if I understand how to add a "row" (rgbw_3 or rgbw_4) to my "file" (bright).  Another thing to consider, when you want to remove a "row", just set the key value to nil. Thus, bright["rgbw_2"] will remove the information stored at that key. The thing is, if you use a dictionary layout (as in the above), you merely reference the new key ("rgbw_3") with your new data ({r=46, g=53, b=108, w=25}). It has now been added. BUT, when you execute the above with the for...pairs() syntax, you will see the information is returned in an unordered list. However, the true value of using the key, data table idea is that when you want to get to a particular key, you merely have to reference it. If you are using an array table, then the only way to get to the "key" you want, you must pass through the table until you discover the key you want. This is the traditional means of storing information in traditional programming languages and is, perhaps, the easiest way to understand data storage.
    I hope this will help you understand the storage methods in Lua. I am new to all this myself. Honestly, I find that the syntax of these tables is almost too easy to believe. That was what prompted me to write the above snippet.
    Good luck.
    PeterV959
