I saw that the time and date of my Fibaro HCL system is wrong and every time I try to change the NTP server or manually set it the system reboots and goes again to 1.1.1970...
Anyone having the same trouble?
Firmware version 4.170.
Maybe it is time to update your firmware
It is a good idea, probably it won't be possible without support help now - the HCL has so old certificates now that probably npt server rejects the request for new time and our servers do not serve the update anymore.
So, @lfvenancio - contact support and ask for assistance.
    Hi guys,
    Thanks for the help.
    I tried to update the firmware, although the option to do that does not appear as is appears on my other HCL.
    I read a bit and some people on other topics gave the idea of changing the battery. Makes a bit sense for my case, because the HCL was "in the shelf" while we were changing the business place.
    Thanks again!
    Have a nice 2023
    You can’t, see the comment of m.roszak
    Hi guys,
    So, the problem is solved... switch the internal battery (CR1220) for a new one. Now the date and hour is working fine with the NTP server.
    Thanks and have a nice 2023.
