Door sensor notification acces control message
I own 5 fibaro door sensors. Just one of them is showing notifications each 4-5 minutes in my history log. The other 4 don’t send the notifications and work fine without the notifications. How can I switch those notifications off, since I think it’s only battery draining?
thnx
5 answers to this question
@Karsten1983Hi, what is the notification about? Try the reset the paramaters. Under advanced > reset parameters
Edited by Fabir
    Hi, Thanks for the reply. The notification says: notification: acces control - window/door is closed. It repeats every 5 min or so. And when opening the window is says the window is opened offcourse. I tried resetting the unit and deleting the sensor in whole. But I keeps giving this notification. I cant seem to find how to turn this notifications of.
    @Karsten1983Do you use Zwave engine ZW3 with the hc3? It is known for strange behavior?
    Hi, I think you mean which version of z-wave I have installed? According to the dashboard I use v4.33. Is that what you mean?
    @Karsten1983You can check it. Start a new Lua scene and enter the folloing code: (on the right side)
    zwave = api.get("/settings/info")["zwaveEngineVersion"]
    print(zwave)
