Walli Switch First-Channel and Second-Channel LED Ring with different Color
Fabir
The Walli Switch is missing an important feature. Now both channels always have the same color in On/OFF Status.  Each Channel LED Ring half, should have the settings to choose a different Color, just like the Walli Controller has.
  • 1 month later...
it can be changed in the Home Center (when not powered by battery but with an adapter) but it doesn't work unfortunately :s
Fibaro should fix this I guess
  • @LP4444LPHi, thank you. Could you tellme which parameter this is?
