There was a need to reset the zigbee module to change the communication channel.
After the reset, all zigbee devices were deleted, but the humidity sensor ID remained in the linked devices.
After that, it became impossible to open the sprinkler device, error 404 occurs.
In editing the device, it is impossible to disable the missing sensor or select another one, the lists are disabled. It is also impossible to remove the sprinkler, a 404 error occurs.
Changing the device configuration via api also returns a 404 error.
How to remove absent sensor, or change linked device id to new device without full reset controller?
On a attached screen - device 275 is not in the list of devices, but is in the list of linked devices.
418 - new id humidity sensor after adding zigbee device
Edited by andrey74
