JR. 0
Hi there. Please give advice if possible. Here's how I got here:
-HCL stopped running scenes (but web interface seemed to be working normally, ver. running was 4.620)
-Didn't remember when I restarted it last time (HCL was running o.k. for long period) so I decided to restart HCL (from web interface)
-HCL started to boot normally (diodes running left-right and back)
-after longer while diodes had changed to running from sides to middle and back = starting recovery mode
-but it never actually finished booting (diodes kept moving as above), web interface not accessible
-I'm able to eventually get into recovery mode after disconnecting power for longer period and connecting power again with reset button pressed.
-then I'm able to select any option available and continue with no problem, but with same result = after recovery/repair/repair from file it always ends in boot loop as explained above.
-I already have custom recovery installed (v1.0-2017 = I installed it long time ago with help from forum:-) so I tried various versions of software available on forum = same result as above.
Is there anything I could try at this point?
Thanks in advance.
