Ire 0
I have a Home Center Lite 3 Gateway (sw version 5.130.64) plus three ZWave Fibaro Heat Controller (ZWave Type 3, version: 4.61) plus three external temperature sensors. Each external sensor is paired with a single heat controller and each heat controller (with its temperature sensor) is placed in a different room with a dedicated temperature schedule.
I have noticed that the daily temperature control chart of the heat controllers (in the Advance settings of the child device id.1) shows the setpoints but they seems different from the temperature schedule I have planned in the Yubii Home Center web application (setpoint showed 8 °C, scheduled setpoint: 21.5°C, actual temperature: 22°C). The situation seems a bit different with the weekly/montly visualisation, where the setpoint is set at the maximum planned temperature of the day . Does anyone know if this is a known issue and if it will be fixed in a new sw release? Otherwise could someone help me to understand what is wrong with my configuration.
Thanks a lot for your help!
Edited by Ire0 answers to this question
