Downlight with dimmable driver controlled by FGD212
Hi
I'm planing to install led downlight and want to use the FGD212 but the led downlight (230v) comes with a individual driver for each led and is not dimmable unless i exchange it with a dimmable driver. Can I still use the FGD212 to dim the lights?
The led downlights in question:
/Robert
@RobertM76Hi and welcome to the community.
I don't know your LED downlights.
Probably you have to try out, if it is working with the fibaro dimmer2 module. I recommend to read first the user manual
. Also start with the bypass2 for the setup.
