Clima Zone
I have only 4 set points, but I need to have 6. How can I do?
Thank you
6 answers to this question
You can't..Unless you create your own QA for climate management and control your thermostats through that QA...
    what is QA?
    Quick App...it is kinda virtual device, that you can develop some functionality for. It is using LUA programing language.
    And here is a fine manual with some examples:
    Is there a difference between creating scenes with time slots or using climate zones?
    Yes, there are some differencies..The main difference is, that you need to create a lot of scenes. If you want to keep the 6 sections / day schema, than it is 42 scenes only for one thermostat/week. The other big difference is, with scenes, you dont have a direct access to your heating system in your app, that you can set your setpoints manualy for, if you want..Your heating system will be only controlled by those scenes. You can't change your setpoints on the fly (only the thermostat device is accessible, but if you change the setpoint on it, your scene will overwrite it)..I doubt it will be a sufficient solution for you..If you really need 6 sections for a day..I think you can try to create the zones regularly for the first 4 sections with Fibaro climate scheduler, and then create two additional scenes for the last two time slots..(i dont know if this would work, but i think it should)..but dont forget, you wont be able to overwrite your last two sections from the zone thermostat that is created for you in your app when you use Fibaro built in climate scheduler..To be honest, it is strange for me a little bit, that 4 sections/day are not enough for you..
