Zamel ROP-02 control with Fibaro Double Switch
Dear,
Could you please advise if it is possible to control ZAMEL ROP-02 switch with Figaro Double Switch?
Currently two lights at my home are controlled by ZAMEL ROP-02 switch operated by a remote button. I am wondering if it is possible to connect ZAMEL switch to Fibaro switch. I would like to have a possibility to control all lights via the remote button connected to the ZAMEL switch plus add the Fibaro functionalities ex. remote on/off, scenes etc.
Attached I am sending diagram showing how I see the connection, but somehow it is not working. Could you please advise how it should be connected together?
Thanks in advance.
Please study the thread where I have given you enough advice. Yes, then it was one output module and now two, but the principle is the same!
@inspirit
Oh yeah.. so yeah.
ROP:out1 - FGS:S1
ROP:out2 - FGS:S2
FGS:Q1 - bulb 1 L (phase)
FGS:Q2 - bulb 2 L (phase)
bulb 1 N - Middle conductor N (neutral)
bulb 2a N - Middle conductor N (neutral)
the rest (fed L + N according to the diagram).
The function will be such that you will control the wireless ROP, it will give an impulse to the FGS and it will only turn on the bulb.
Thanks to this chain, you can control FGS independently or based on scenes.
Importantly, ensure that the ROP is operating in pulse mode.
My recommendation: leave the solution with ROP and switch directly and only to Fibaro.
  • 3 weeks later...
    On 1/27/2023 at 9:46 PM, Martin_N said:
    @inspirit
    Oh yeah.. so yeah.
    ROP:out1 - FGS:S1
    ROP:out2 - FGS:S2
    Thank you @Martin_N a lot. It works perfectly :)
