nicopret 17
While trying to optimise my HC2 zWave routing about three month's ago, I noticed that default hidden slaves differ between the older FGS212 and FGS222 double switches and the newer FGS223.
For the FGS212 or FGS222 the defaults after inclusion on my HC2 are:
deviceID.0 – On/Off Switch - not hidden and allocated to relay1 switch
deviceID.1 – On/Off Switch - hidden and allocated to relay1 switch
deviceID.2 – On/Off Switch - not hidden and allocated to relay2 switch
For the FGS223 the defaults after inclusion on my HC2 are:
deviceID.0 – On/Off Switch – hidden and allocated to relay1 switch
deviceID.0.1 – Remote controller
deviceID.1 – On/Off Switch – not hidden and allocated to relay1 switch
deviceID.2 – On/Off Switch – not hidden and allocated to relay2 switch
When I noticed this I thought I may have configured the older devices incorrectly many years ago and decided to swap the hidden/unhidden config on the older devices to be consistent with the newer FGS223 modules where deviceID.0 is hidden and deviceID.1 is used to control the on/off switch (example in spoiler below). I must admit I have never really understood why there was a hidden and un-hidden device for the same relay. I have, however, since seen a forum post which explained that this was for backward compatibility and that they are the same.
I'm still desperately trying to locate what is causing random 503 errors on my HC2 and I’m once again reviewing the output from the SanityCheck script 1.1.5 by @petergebruers and in hindsight now realise that the hidden/unhidden swop was maybe not the correct thing to do? The ticket with Fibaro support to troubleshoot the 503 problem have been for open for 2months now and we have unfortunately not yet been able to identify the root cause.
Any advice or feedback from the Fibaro guru’s @Sankotronic @petergebruers@cag014 will be highly appreciated.
Thank you
