Got a notification about a new beta today..
After install my HC3 will no longer boot, only the "house" icon is on.
There is no response to any og the two buttons, cannot enter recovery when holding power button. Seems completly dead...
"House" icon goes on when applying power to the unit and stays on..
Any suggestions?
Any suggestions?
Maybe clear your browser cache.
Why Clear Cache and Cookies?
Clearing the cache and cookies from a web browser is an important first-step for almost any troubleshooting for internet browsing. The 'cache' is a tool used by your internet browser to speed up the page loading process. However, sometimes it can cause a problem when websites are updated and developed as files saved in the cache may conflict with what's actually coded into the website. Clearing cache and cookies is a way we can be sure that any issues you may come across are actually something wrong with the website, rather than inconsistencies caused by using different browsers.
Edited by ppeterr
    Thanks!  But my browser has nothing to do with the actual HC3 unit not booting..
    Aha, i see. I misunderstood. I thought you see the "house icon" in your browser.
    But you probably mean on the small HC3 display. Uhmm....thats bad.
    Someone do update and running
    @Spett enter on hc3 recovery and restore GA version. Try disconnect power to check if after that botloader and button workings
    Yes, no problems
    No problem so far (on my test/develop HC3)
    My installation is crashing at some point between 10 minutes and several hours, and then rebooting. I have yet to figure out the exact cause. To be specific: FW 5.131.52.
    I have seen some great features and improvements in the web interface, though. I was already using the Zigbee (beta) version.
    Edited by rliessum
    After a several "reboots" my system decided to kind of boot again, all leds go amber but the last security(?) led keeps blinking and web interface is not responding. From there I was able to do a recovery boot to switch system image.
    Whats weird is that both A and B image was on 5.130.64 not the newest 5.131.52.
    Got the system up and running again after switching image and decided to give the newest beta another try but with the same result...
    I'm now back to 5.130.64.
    Is 5.131.52 working for anyone else?
    Edited by Spett
    Working here on test system
    My restart problem seems to be related to a QuickApp that behaved badly, so I continue as well with the beta.
    Hi @rliessum ,
    if this bad QA is downloaded from Fibaro forum or marketplace can you please share which QA is behaving badly so author can take necessary steps to correct the code?
    Thank you!
    1 hour ago, Sankotronic said:
    Hi @rliessum ,
    Thank you!
    I can do that for sure since it's my own QA. Which is private for now since I just started development on it.
    I see in my HC3 notifications that there was a problem dumping Nice memory when I tried to update, maybe that's where the problem is. Although I dont use any Nice devices....
    FW 5.131.52 is not availeble for me to update to anymore. Have they revoked this update?
    The up-date work for me.
    The only issue I do face is that on the "scenes" setting I do not see the hidden scenes ( and no button for such access as on the previous software versions ).
    Sorry, my bad as I did not spend enough effort to find the "hidden" and "visible" buttons addressing the scenes.
    They are available under the "filters" button.
    W dniu 28.01.2023 o 07:52, RudyT napisał:
    Yes, no problems
    It is working for me too, but I have issue with new beta Yubii 1.18 on my Ipad. After 1 second is crash and I see only white screen :(
    edit:
    Uinstall of 1.17, Ipad restart and new installation of 1.18. Now is working
    Edited by MacinZ
    no beta its gone from hc3
    Since my hc3 went haywire after a while, I understand why. The GUI looked pretty good, especially working on the GA again, that is going into the right direction.
