Hello @m.roszak, @K.Drozynski,
New beta update 5.131.52 is published, but no new forum thread about it here?
Is this beta published too early or you forget something or forum is again put on shelf until better days come? 😕
I was wondering the same yesterday evening :) But I thought it's something on my end.
A quick question, though - if I update to this beta, will I be able to revert back to 5.130.64 stable or update to a non-beta release afterwards?
beta is not there anymore
@Sankotronic, That one should be Alpha.
    Hi @jakub.jezek ,
    Well, alpha or beta it is not available anymore. But if I remember correctly there was word "beta" in the version. ;-)
    Probably it was put on public by mistake.
    @Sankotronic @jakub.jezek Yes, the version was unfortunately published globally accidentally - this was intended to be an alpha release which may cause system instability. There was no other option, but to remove the version till the actual Beta is ready.
    I have just created a separate thread in which we explain what users who have already downloaded the file can do in case of any problems.
    you can always restore your backup made with specific version, or restore it and convert to higher version. This is however only for GA and official beta.
    With alpha versions, this might sometimes not work - that's why they alpha and not for public use. In case you already installed 5.131.52, no worries, as Fibaro know that this version has been published as beta for everyone, they will ensure that update to beta or GA will work.
    Alpha even, by accident. It explains a lot.
    After this "alfa" update and Yubii Ipad app 1.18 everything is forking fine for me.
    Finally all custom icons are visible.
