I have a new MCO Home A8-9 multisensor. I have added to my HC3 and all data’s are correct,  but the CO2 value always 0 on HC3 surface (you can see in the middle of the picture below).
The Multisensor shows always the correct/actuall CO2 value.
I have sent already back a Multisensor A8-9 to the seller because of the above mentioned problem. I have got a new one, but the problem is still the same as before.☹️
I have an older Multisensor A8-9 is works well, so the CO2 value is correct.
I have compared the parameter list and the parameter sablon and the Zwave version values, but all are same in case of the two Multisensor’s setup (new vs. old).
Do you have any idea?
Edited by nadtom
It seems to be a problem with this device:
