I have updated to this beta version, but I cannot turn on remote access anymore. If I try several times I get some kind of 503 error.
i guess there is a issue with remote control.....
So this was not good.
Remote access closes itself.
Edited by systemfel
yes, it doesnt work
Yep, so also the phone app is not working....At lease not remote
Edited by ErikP
Same here, neither the remote access nor the Yubii app are working. 😡
PLEASE FIX
Edited by Sonzy
  • Yes, it doesn't work in Czechia either
Edited by Green120
even without this update not possible to remote connect.
Indeed. Same here. More likely related to the server at Fibaro then the update.
As everyone has noticed, it is not the update but the Fibaro service that is not working. @m.roszak
The same in my case. Anybody know when they fix it?
  • Thanks 2
@m.roszak , Hopefully this will stop spamming of the forum!
    10 hours ago, m.roszak said:
    Ok, but would be nice to have the possibility to connect to hc using yubii with a LAN ip, if I am in the same network (or through VPN).
    This outages are really bad if I am not at home and cloud is not working, as there is no backup plan to access it rather than web ui.
    Edited by rareszehan
    You can...
    Log off from application and then on login screen click "offline" option.
    This will do the job just fine.
    You need IP of the gateway, login and pass for local user.
    Its Now working in Egypt 😀
    15 hours ago, m.roszak said:
    You can...
    Thanks, didn't knew about this.
    Same here
