Zigbee Appartme APRM-04-001 and HC3
Hi! I'm a newbie in fibaro world.
I bought thermostatic valves type APRM-04-001 from Appartme. It works on Zigbee Protocol.
Before I updated my HC3 to 5.131.57 firmawe I could add the device but it didn't appear in the device list. Now, after update, I can see it but there are no parameters to set up and HC3 doesn't get any information (such as set temperature) from the thermostatic valve. Connection with valve is direct - without any dedicated zigbee gateway, mqtt server or sth. else.
In the main tab of the device list I can only see some general informations (screen in attachment).
And the question is - Is there any possibility for now to connect such device directly to the HC3? Are there any known apps from market place which could do it. I couldn't find nothing about Apppartme producer here. The device is similar to Aqara E1 or Haozee (maybe it's even the same product).
I'd be very grateful for any advice.
HC3 does not support zigbee thermostats/radiator valves yet.
But it is planned for the future releases.
