HC3 'if then else' scenes
Hi, I've been using HC2 for about 10 years and while I'm not a programmer, I have gotten comfortable with HC2 over the years with all the great help and examples from this forum.
I recently moved to HC3 and the new way of writing LUA scenes really has thrown me in a loop.  There may be a super obvious answer but I can't figure out how I can write a simple scene that does one set of actions on one condition and another set of actions on another condition.
For example, when scene is triggered through double click on a switch, I would like to turn on light1, light2 and light3 if lux value is < 60, else turn on light4, light5 and light6.
This was easily done in HC2 but i can't seem to get it to work in HC3.  Been searching through the forums but I can't seem to find a starting point.  Is there someone that can point me in the right direction to get started?  Thanks!
    Any kind soul? I tried to add both conditions in the trigger section but not sure how to activate them
    @Angelus
    Hi, I'll give you a little hint:
    in the conditions for starting, put only the input condition (double-click). This will start the scene.
    In the action, write a condition that compares the value of lux. (if it is less than 60, turn on devices 1,2,3...) else turn on devices 4,5,6.
    The second option (if you don't want to think about the correct syntax of the launch conditions) is a combination of two scenes. For example, with a block scene, set a trigger condition (double-click) and add a new LUA as an action. The new LUA can be empty in conditions, and in actions you will have a condition with the value of lux, see above.
    I guess that would be simply achieved in block scenes if something like "IF Block" existed. Same as the delay or group exists there. I would strongly call for such improvement in block scene. It would drastically decrease the amount of scenes needed to perform a bit more complex scene without a need of using LUA for that.
