[HC3] slider QA value
Kage
is there a way to get a slider value if the QA is in a run=1
normally you have like this
function QuickApp:onChangedTimer(timerSet)
    if timerSet~=nil then setTimer=timerSet.values[1]statusDetectie()
    else setTimer=setTimer
    self:updateView('timer','value',tostring(setTimer))
    if setTimer>0 and not lV then lightOnOff('On')
        Debug('grey','lamp on via setTimer')
when asked the name "we will not asked" say set timer at 60 then the slider goes to 60 lamp goes on timer runs in run=1
the line self:updateView....... is for if the door is open en and no timer is set then the timer is automatically set at doorTimer the slider gets a update
if i say set timer at 40 nothing happens until the run is over it restarts the timer at 40
how can i set or get the value if slider is changed while run=1
if i call onChangedTimer() then i cant get value because of () this is nil. i know 🤣
thx
