After the a.m. update my Yubii on my iPhone is not working as it should, while on the iPad is working well !!
Can this be from the update or it’s a coincidence? Is anyone else having the same problem?
This is a system update, not a support application - probably not this topic.
I had the same problem on android but reinstalling helped and now it's ok.
    I reinstalled the app several times, but I still have the same issues.
    Are you a beta tester of Yubii app?
    Do you have the same version of app on both devices?
    I’m not a beta tester.
    Yes I do have the same version on both devices.
    Mainly the issue is when calling Remotec, on the iPad it’s called (loading all AC data) every time while on the iPhone not necessarily to be loaded and if it’s called it’s takes a longer time. This happen with all my Remotec devices. Before this update everything was working perfectly.
    One other non important thing is that the customized icons in the scenes are shown on the iPad, but are never visible on the iPhone.
    Edited by Sonzy
