Sankotronic 2,375
First about my system: HC2 on 4.630 with 114 physical z-wave devices included.
First what happened is that one of the Fibaro motion sensors just disappeared from HC2 without any my involvement. HC2 was running smoothly during that time and nothing was touched or changed. Fibaro motion sensor that was deleted from the HC2 was with depleted battery. After reinserting new battery it flashed red which means not included to any z-wave network. I added it to HC2 without any problems. Question is how it is possible that z-wave device get removed from HC2 without me touching anything?
Today I noticed again that another Fibaro motion sensor is stuck in breach mode and when I checked sensor it was flashing on motion, but not on shaking (tamper). When battery is replaced it flashed once with red light which again means it is not connected to the z-wave network. Battery on this one is still OK. In this case, motion sensor is still visible in the HC2, only of course not updated.
Now I have to forcibly remove it from HC2 since usual removal does not work and then include it again.
Is there anyone out there with same problem? Is there any explanation why my eyes are kicked out from the z-wave network?
Thank you in advance for any information provied!
Edited by Sankotronicchanged title to include HC3
9 answers to this question
