Bips 0
I have set a global variable called "LightsOn" in the HC2 variable panels with a value of 0
What im trying to do is set the value to 1 if the time of day is after 17:00 and before 07:00.
Got other scenes that will switch on lights if the value is 1, which seem to work ok when the value is 1.
Problem im having is the LUA code im using doesnt trigger by itself, if i run it, it sets to 1 if the time is from 17:00-07:00, and zero if not.
How can i get the code to trigger automatically, even though i have set it to auto
Or is there a better way of setting the global variable?
%% autostart
%% properties
%% weather
%% events
%% globals
LightsOn
local sourceTrigger = fibaro:getSourceTrigger();
function tempFunc()
local LightsOn = fibaro:getGlobalValue("LightsOn")
if (
( (tonumber(os.date("%H%M")) >= tonumber(string.format("%02d%02d", "17", "15")) or tonumber(os.date("%H%M")) <= tonumber(string.format("%02d%02d", "07", "00"))) and (math.floor(os.time()/60)-math.floor(1676306520/60))%1 == 0 )
then
fibaro:setGlobal("LightsOn", "1");
fibaro:debug("Stage 1")
fibaro:debug(LightsOn)
setTimeout(tempFunc, 60*1000)
if (sourceTrigger["type"] == "autostart") then
tempFunc()
else
if (
then
fibaro:setGlobal("LightsOn", "0");
fibaro:debug("Stage 2")
