zigbee problem
I have an HC3 and since it became possible to connect zigbee devices, I bought myself some temperature sensors and some relays. At first everything was ok, they connected to my HC3 and even worked...for a while!
Now there is a problem, more precisely 2:
1) I have a bad door opening sensor, which itself (HC3 is not to blame here, because that's exactly how it works with HA+zigbee2mqtt) just doesn't show the status correctly...I just took it and threw it away. But I did not delete it from the system.
1.1) And now I physically do not have that sensor and I cannot remove it from HC3, since there is no force removal for zigbee, as for zwave devices. How do I delete a defunct zigbee device?
2) Another problem is that from time to time my zigbee devices just remove themselves from my HC3... here I am convinced that it is also not the wine HC3, but the wine device itself, so the question here is who will have this situation?
PS: sonoff snzb-02 self-removable temperature sensors
5 answers to this question
I have the same Problem nr 1.1
so I follow this topic
As for 1.1, there was some issues with this and it is removed for now - it will be back.
For now 2 options ara available, just hide it for now or contact support - they will help get rid of it if this can't wait.
As for issue #2 - we seen this, not much we can do. The less Chinese the device the higher chance it won't happen.
As old people use to say, "no money no honey" :-D
Ja nie mogę... po prostu po polsku tu napiszę.
Kupiłem HC3 ze względu na Zigbee a tu taka niespodzianka.
Porażka ...🤦‍♂️żenada.
Dokonałeś złego wyboru! Jak chcesz mieć zigbee to masz pełno innych pewnie lepszych bramek. Fibaro nie nadąża za konkurencją, może produkt dobrej jakości, ale 2-3 lata za innymi.
Wrong choice! If you wanted to have zigbee, you have plenty of other, probably better gateways. Fibaro cannot keep up with the competition, it may be a good quality product, but it is 2-3 years behind others.
