You cannot control the sockets separately on zigbee Silvercrest 3 gang switch
Guest honekr
In this version of the software, the sockets on the zigbee Silvercrest 3 gang switch cannot be controlled separately. Only first outlet is always switched on or off.
In version 5.120.10, separate control of individual sockets works.
Please remove and add again the device to the system and let me know if this solved your issue.
Guest honekr
    When I remove and added again the device to the system, state is the same. Device number 326, 327 (326.0), 328 (326.1) and 329 (326.2). Each switch on and off controls all three sockets at once. In version 5.12.0.10, each socket is controlled separately. I am attaching screenshots of the device settings.
    A second device of the same type cannot be added to the system. The HC3 system will start to detect it, but the configuration is not complete.
    Edited by honekr
