nosern 0
I have a Homey Pro system with several Figaro Smart Implants. Very flexible and great devices! One of these implants are logging the voltage of a solar cell equipment, AN1 to the solar cell and AN2 to the battery charger output. The voltage output is in the range 12V to 18V so I have a used a resistor divider to get a voltage between 6 and 9 voltage as input to my Homey Pro system. The analog inputs are configured without the internal pull-up resistor. Is there any way that I can configure the Figaro app configuration to add a gain of 2 to these voltages to display the correct value in my Homey Pro system? It seems that I can only configure the change of voltage and time for updating the value, but no offset/gain adjustment of the voltage values? I assume that this will always be an issue when converting a voltage signal to the 0-10V range for the implant.
4 answers to this question
